Sharp mx m550
  • davebtech
    • Apr 2015
    • 176
    Sharp mx m550
    Scans and copies are sometimes cut off an inch to inch and a half at top of portrait scan or copy? Anyone seen this before? Thanks Dave
  • faxman28
    • 435
    Re: Sharp mx m550
    do adjustment 7 and 8 in the adjustment section of service manual, basically sim 50.
    • davebtech
      • Apr 2015
      • 176
      Re: Sharp mx m550
      Why would these values need changing from factory ones? Thanks dave
      • ZOOTECH
        Senior member of CRS
        • 3375
        Re: Sharp mx m550
        Worn parts (clutches, rollers, sensors), new supplies (DV, drum, fuser); even from the factory, adjustments need to be made at setup.
        • davebtech
          • Apr 2015
          • 176
          Re: Sharp mx m550
          I hear ya seems to be doc feeder thing besides pick up/ sep rollers what else has anyone had to replace? Never happens on prints
          • ZOOTECH
            • 3375
            Re: Sharp mx m550
            Well, you pretty much narrowed it down - does the problem show up copying off the glass?
            • davebtech
              • Apr 2015
              • 176
              Re: Sharp mx m550
              Never
              • faxman28
                • 435
                Re: Sharp mx m550
                I have seen this happen on a 620 that we rent out for a month every year, for a music fest , they call at least once for copies being cutoff at the top(this is when all centering adjustments are done before it goes out. ) its always the doc feeder and it is 2 different 620s that do it . I think it is a scanner bd issue(power problem or static ) but it throws no codes and doing the centering adjustment for the adf fixes it. and it runs fine for the duration, they do about 65000 copies in a month and most through the adf. and when it comes back to the office it runs fine as we use it as our main walk up copier for customers.
                • davebtech
                  • Apr 2015
                  • 176
                  Re: Sharp mx m550
                  Yup sounds like you have run in to it these folks run a ton of scans /copies 60000 a month also I wonder if there was ever a bulliten from sharp?
                  • ZOOTECH
                    • 3375
                    Re: Sharp mx m550
                    If you know the 'backdoor' entry for test commands, you can try 88-7 (SCU Memory clear). When it finishes and reboots, the 'Please Wait' can take several minutes, but you can make copies off the glass.
                    NO, I will not give out the backdoor entry.
                    • davebtech
                      • Apr 2015
                      • 176
                      Re: Sharp mx m550
                      Yup I know the other sim entry does this just reset the feeder board?
                      • ZOOTECH
                        • 3375
                        Re: Sharp mx m550
                        Yes. It's worth a shot before replacing any pwbs.
                        And, you may have recalibrate for centering as faxman28 said.
                        • davebtech
                          • Apr 2015
                          • 176
                          Re: Sharp mx m550
                          Do you know what is exactly lost with this reset?
                          • ZOOTECH
                            • 3375
                            Re: Sharp mx m550
                            No, I don't - I just know it's taken care of some weird doc feeder stuff.
                            • davebtech
                              • Apr 2015
                              • 176
                              Re: Sharp mx m550
                              Ok great as long as all the scan destinations ect are ok just a little nervous..... Thanks for all this input
