MXM354 F1-15
+ More Options
Posts
  • ivan123
    • Oct 2014
    • 54
    MXM354 F1-15
    Dear colleagues, I have some problems with one MXM354+FN23. About month ago it was code F1-15 (finisher lift tray motor trouble). I checked finisher, motor was not working in sim 3-3. Than I checked finisher pwb and saw that is no 24V on lift motor (on pwb some components was failure: some transistors, fuse...). I dissasemlied lift motor and connect to DC 24V supply, worked normally in both directions. So I ordered new finisher pwb from sharp, changed it, and machine worked normally. Today, customer called me, and told me that machine on display have again F1-15!!!
    After first changing finisher pwb, machine work about 20 days.
    Tomorrow I will go to customer, but if you have some proposal what to check, it will be good.
    Sent from my D2303 using Tapatalk
  • drowranger
    • Jul 2015
    • 122
    Re: MXM354 F1-15
    you can get this error if something hits the finisher tray. also pwb can be blown by a power surge. You or customer might have to put a surge protector in that case. Good luck !!
    • ivan123
      • Oct 2014
      • 54
      Re: MXM354 F1-15
      We changed whole finisher
      • michaelc
        Field Tech
        • Mar 2011
        • 590
        Re: MXM354 F1-15
        Expensive fix, but it worked
        It didn't say that I couldn't do it in the manual.
