Sharp MXM350 Stays on Warming-up message at all times
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Sharp MXM350 Stays with the WARMING UP message, the machine has been serviced fully, I've changed OEM drum, OEM Developer and OEM toner brand new, even changed the DV unit from a working machine and still the same, cleaned all sockets for DV unit , at no avail.
    I have to admit that, all of a sudden (like 2 hrs later) the machine goes to READY but if you turn it off or take the units out and put them back again the message returns, "WARMING UP" and the machine is not "warming" no way, nor moving (no toner is been added) just stays idle.
    Any comments are welcomed.
    THANKS.
    Jaime.
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • sharptech1
    • Oct 2011
    • 163
    Re: Sharp MXM350 Stays on Warming-up message at all times
    sim 14?
    • ZOOTECH
      Senior member of CRS
      • 3375
      Weak fuser lamp.
      • 1stcavvet
        • Apr 2015
        • 231
        just had a machine do this, a Sharp mx4501, it was the lower lamp or the lower thermisters I sold them a whole new fuser, cheaper than a rebuild kit and a new lamp. Not to mention I saved them the price of labor to rebuild it GOOD LUCK
        • rapidocument
          Multibrands Tech
          • Jul 2012
          • 381
          Yes, I ran sim 14 and 16 too, no lucky,
          Im going back monday to check fuser lamps and stuff,
          thanks for your ideas,
          Jaime.
          • lky1978
            • Mar 2009
            • 483
            Jaime.
            1) weak/ faulty one of the fusing lamps
            2) 240v lamps working with 120/100v power source
            • Jaws
              • Oct 2007
              • 235
              I had one doing sort of the same thing and it was a bad solder joint, on one of the large capacitors, on the power supply.
                • 23008
                Thanks for mentioning the power supply. I was thinking of that too. =^..^=
