Mxm453n grey background
  • SDtech619
    • Dec 2013
    • 40
    Ok I'm chasing my tail here...the background is very slight when you do internal prints and of course it gets darker when making a copy. Replaced dev unit,dev,drum and transfer assembly...I may start shooting for a board?? Suggestions, please! Checked some AE sim...and some other density simulations...Thx ahead of time
  • drowranger
    • Jul 2015
    • 122
    Re: Mxm453n grey background
    change the mc grid & drum blade first . can be either. then the process unit
    also check the sim 46-19 auto exposure gamma setting default is mode 2, mode 1 will make it darker
    • bilyahn
      • Dec 2006
      • 1465
      drowranger is correct with this. Have had it happen a couple of times and both were caused by the charge unit. One of the instances was with a fairly low meter machine (50K).
      Good luck.
      Bil
      • Jhonjon
        • Sep 2013
        • 208
        Correct me if I'm wrong the problem of your machine is overtone?! A lot of this machine i handle, overtone is one problem i frequently encountered. Replacing consumables resolve some of the issue but some problem I've encountered is cause by the user who want to save money by purchasing compatible toner. Some problem is the compatible upper fuser roller toner stuck to it...
        • SDtech619
          • Dec 2013
          • 40
          Thanks for the suggestions guys...I'll reply with fix once I figure it out. This equipment is in a prison and well I certainly don't want to go back there any time soon. Customer hasn't noticed but I want to address the problem before it gets worse. I'll be checking on it bent time I go in. Thx again!
          • SDtech619
            • Dec 2013
            • 40
            FIXED-UPDATE
            So it ended up being the development bias was way off. Used simulation 8-1 to fine tune it. Thanks guys!!
