Sharp MX-C311 L4-16
  • glenbennett
    • May 2015
    • 68
    Sharp MX-C311 L4-16
    Good morning I was hoping that someone might help me with a code L4-16 on my Sharp MX C311, is there any way to reset this code or what it means and what I can do?
    Thank you so much,
    Glen Bennett
    Thank You,
    Glen Bennett
  • Jhonjon
    • Sep 2013
    • 208
    Re: Sharp MX-C311 L4-16
    Thank you so much,
    Glen Bennett
    Fusing pressure release trouble
    A change in the fusing pressure release sensor signal cannot be detected within the specified time afteroutputting the fusing pressure release motor.Fusing pressure release sensor trouble.Fusing pressure release motor trouble.Pressure release drive gear and pressure release idle gear trouble.PCU PWB trouble.
    Connection trouble of the connector and the harness
    Replace the fusing pressure release sensor.
    Replace the fusing pressure release motor.
    Replace the pressure release drive gear and the
    pressure release idle gear.
    Replace the PCU PWB.
    Check connection of the connector and the harness.
    • ZOOTECH
      Senior member of CRS
      • 3377
      The pressure release flag has probably broken due to improper shut down.
      • igi
        • 1507
        Hi
        try to reset with sim-14
        • rufio311
          • Jun 2013
          • 12
          If the trouble code doesn't clear with SIM 14, then the pressure flag is most likely broken. Sharp has updated this part multiple times. The current part # should be MLEVP1112FCA4
          Or replace the whole fusing unit.
          • bdcrandall13
            • Sep 2010
            • 236
            The fuser drive gear could be missing some teeth also.
            • Lopakadee
              • 11
              i would go with the gear being broken. i have done that a lot
              • Toner Boy
                • Aug 2007
                • 366
                Broken flag PN MLEVP1112FCA4, the newest part number that I'm aware of (not that it resolved the heat damage issue either...).
                • Boringguy4
                  • Aug 2015
                  • 29
                  Ive been fighting this issue too. Without ordering a new fuser. Check the solenoid, lock lever, and one way bearing on the pressure release lever and shaft. Good luck.
                  • michaelc
                    Field Tech
                    • Mar 2011
                    • 590
                    This has happened to me once. Would check for a unicorn in the ADF.
                    It didn't say that I couldn't do it in the manual.
