Sharp Lines on scanned document
  • Jack79
    • Jul 2014
    • 312
    Hi.
    I have Sharp MX-3100n which makes lines on scanned document from glass and ADF. Lines are all way long (longer edge on A3) and always in the same place.
    I attached scanned chart. You can see lines on printed woman face.
    Prints are fine without lines so there must be a problem with scanner only.
    I cleaned glass, mirrors under adf glass (2 mirrors) and lens under black plastic cover located on the right side under the glass but without any result.
    Could you help me to solve this problem please?
    Jack
    • 23008
    Re: Sharp Lines on scanned document
    I agree that it is a scanner issue. If this were my call I would clean the scanner optics again very carefully, including the two mirrors, the laser slit glass both sides, and the face of the CCD lens. I would also clean the scanner rails and apply just a few drops of straight weight 30W motor oil to the scanner rail. If you are getting friction from the scanner, the mirrors can tip, showing a different section of the mirror face. =^..^=
    • Jack79
      • Jul 2014
      • 312
      Thanks for reply. I will clean it again. Do you think is it anything else what can cause it?
      Regards
      Jack
        • 23008
        I had a Bear once that was fixed by reseating the CCD ribbon cable.
        #1) that's very unusual
        #2) always be cautious with ribbon cables. It's easy to damage the contact surfaces and latches, and the latches are sometimes not so easy to figure out.
        • sharphead
          • Aug 2009
          • 285
          Bit late on this but you could calibrate the CCD array using 63-3 and a sit chart
          • Jack79
            • Jul 2014
            • 312
            Unfortunately I do not have SIT Chart. Should I go to 63-5?
            • MdangerP
              • Sep 2014
              • 45
              are the lines there when you run black and white?
              • ambus
                • Dec 2012
                • 6
                I see color lines thru the grey's in you sample. Do as blackcat suggests. Have firmware handy.
                • ambus
                  • Dec 2012
                  • 6
                  I see color lines thru the gray. Do as blackcat says. And have firmware handy.
                  • Jack79
                    • Jul 2014
                    • 312
                    Lines are not so visible like on color copies. They are not visible between pictures (only in the middle (between pictures) I can see 4 cut lines - about 2cm long). Lines are visible in the picture - woman face, RGB belts)
                    • spanky
                      • Sep 2012
                      • 468
                      Don't forget to remove the cover over the lens so you can clean the back side of the lens and blow off the front of the CCD.
                      • Jack79
                        • Jul 2014
                        • 312
                        Hello blackcat I followed your advise and cleaned optic again. You were right saying 'very carefully'. I had to use a bright light to find a very little dust on mirror. That solved my problem. Thanks.
                        Jack
                          • 23008
                          Congratulations on your success! =^..^=
                          • ZOOTECH
                            Senior member of CRS
                            • 3375
                            Glad you got it fixed - the bright light always helps when cleaning mirrors checking for dirt or haze.
