Sharp AR-M317 jamming when making two sided copies.
  • tibbs
    • Aug 2008
    • 225
    Hello am not a sharp tech and we have no sharp techs in our area. I have an AR-M317 that jams when trying to make two sided copies. The message is missed feed has occurred.
    Any help will much be appreciated.
    • 23006
    Re: Sharp AR-M317 jamming when making two sided copies.
    What jam codes? =^..^=
    • Paulm
      • 69
      Depending on the age of the machine your delivery unit right above the fuser may be shot. They tend to warp from the heat and manifest that problem. You can stick your head under enough with the fuser out to see if the paper path is warped.
