Sharp arm 257 developer pull
  • davebtech
    • Apr 2015
    • 170
    More and more of these workhorses have been doing this on me .Anyone have a proved fix? Thanks Dave
    • 22995
    Re: Sharp arm 257 developer pull
    Is the top cover warped, or the seal curling down, scooping developer off the mag roller? =^..^=
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      Remove the seal along the top of the unit, or change it with the maintenance kits. It often folds itself inward and pries DV from the mag roller.
      • okidokiHB
        • Aug 2015
        • 7
        Hi
        how old is the main charger ?
        • OEM1
          • Mar 2015
          • 32
          There are a few reasons this happens. The seal the other guys have mentioned should be replaced every PM. The best way is to order the DV unit cover for the ARM277. It comes with the seal already installed. the new one doesn't. The DV unit can be a problem and is inexpensive. The main charger is a definite cause and should be replaced every 3-4 PM's. Better yet the entire drum unit. I have replace the main charge only to have to go back after more DV dump and replace the whole drum unit. somehow the plastic must conduct when it gets old. Also, never,never use aftermarket drums and toners on Sharp 200 thru 317 series. I have 257/277's in the field with 700k on them running 50k per quarter and no problems.
