What would keep the copier in this cycle I am about to describe? I turn it on and the display comes up with the Sharp logo displayed on it, then the fan(s) come on. Eventually the display goes off and so do the fan(s) and continues to do this without ever giving an error code or booting up. Thank you for any help given.
Sharp AR-M550U
Re: Sharp AR-M550U
What would keep the copier in this cycle I am about to describe? I turn it on and the display comes up with the Sharp logo displayed on it, then the fan(s) come on. Eventually the display goes off and so do the fan(s) and continues to do this without ever giving an error code or booting up. Thank you for any help given."You can't trust your eyes, if your mind is out of focus" -- -
Re: Sharp AR-M550U
Does the hard drive spin up? If the HDD starts, stops, starts, that's where I would start. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Re: Sharp AR-M550U
If machine is on network a bad packet sent over as print job will cause said actions.. Unplug cable and see if it will boot.. If so then must find print job causing trouble or just cancel all jobs on server.. Seen this quite a few times .. Actually just had exact scenario at a bank with Dragon 2 and sure enough once all jobs had been wiped out machine booted with nibtriubleComment
Re: Sharp AR-M550U
If machine is on network a bad packet sent over as print job will cause said actions.. Unplug cable and see if it will boot.. If so then must find print job causing trouble or just cancel all jobs on server.. Seen this quite a few times .. Actually just had exact scenario at a bank with Dragon 2 and sure enough once all jobs had been wiped out machine booted with nibtriuble“Boring damned people. All over the earth. Propagating more boring damned people. What a horror show. The earth swarmed with them.” BukComment
Re: Sharp AR-M550U
I also have a copier at a bank (MX-M450) that responds the same way, there must be a bad font in some of their software.Comment
Re: Sharp AR-M550U
Replying to "tcypy1961" I have had many of these on all the ARM455-MXM450 series. It is always a computer with the wrong drivers on it. IT guys are lazy and put on the first driver they find and will not believe you when you tell them the solution. If you can't find the computer causing the problem you may have to resort to changing the machines IP address and then the port on every computer. With portable devices these days it could even be someones IPhone or tablet causing the problem.Comment
