MX-M464N shows error F2-70 at installation
  • muthuk7
    • Aug 2010
    • 57
    [Error Code] MX-M464N shows error F2-70 at installation
    Hi Friends
    I have 2 brand new machines different locations which shows the same error while installing the machine. I have performed the develop adjustment and it was completed successfully . When i put the toner in it shows F2-70 .
    Case 1 : I have replaced 2 new toners and updated the firmware . but still the problem persist
    Case 2 : I have replaced toner , developer unit, MFPC PWB & PCU PWB but the outcome was same.
    Could you please advise.
  • faxman28
    • 435
    Re: MX-M464N shows error F2-70 at installation
    F2-70 is wrong toner or toner chip error, make sure oem mx-560nt toner.
    • jp74msj55
      • Oct 2014
      • 151
      Make sure you have genuine toner MX-560NT.
      • nmc
        • Jan 2011
        • 10
        Yes!
        I think Wrong Chip
        • muthuk7
          • Aug 2010
          • 57
          Dear Friends,
          Thanks for your valuable reply and i have tested the same toner with other machine and it was working fine .
          Could you please share your field experience if you have any
          Thanks in advance
          Mu
          • Jhonjon
            • Sep 2013
            • 208
            Originally posted by muthuk7
            Dear Friends,
            Thanks in advance
            Mu
            Can you tell us what region are you in and what toner are you using?
            • muthuk7
              • Aug 2010
              • 57
              Hi Jhonjon
              Thanks for your kind reply
              i am from MEA ( middle east & Africa ) region and i am using MX-560FT toner .
              For your kind information the toner which was giving an error worked with another machine . So there wont be toner issue.
              IT some thing in Machine ( engine ) side.
              • Jhonjon
                • Sep 2013
                • 208
                Hi Jhonjon
                Try to open the back cover remove the chip connector and put the toner or try to put only the chip if the machine will run...If problem still there check the chip connector, cable or even the board. You didn't mention if you are using original toner. When I'm in the middle east a lot of compatible even look a like toners i've encountered some toners will work some are not. Are you a dealer in the middle east?
                • faxman28
                  • 435
                  check sim 26-6 , make sure it is set for your region, do you get install toner cartridge message if you leave toner out of copier.
                  • MHeon71
                    • Oct 2008
                    • 489
                    As unlikely as it may be, there is a tech tip for F2-70. TT-060313_3
