Sharp AR M550 Error Code F2-37
  • Taggerung08
    • Sep 2014
    • 60
    [Error Code] Sharp AR M550 Error Code F2-37
    Howdy, I have a sharp with a F2-37 error that keeps popping up every couple of days. I removed the PCU and checked the harness connection for the drum marking sensor everything looged good and I reseated the connection to be on the safe side. Did the SIM 44-02 and everything seemed to work okay for a few days, but the code came back.
    Can this code be caused by a worn out drum? See picture attached.
  • travi
    • Jan 2008
    • 129
    Re: Sharp AR M550 Error Code F2-37
    Yes. It is time to install a new drum.
    • Taggerung08
      • Sep 2014
      • 60
      Thanks! I figured it was the obvious answer, but wanted to check if there could have been another source of the error!
        • 23010
        [ATTACH=CONFIG]31516[/ATTACH]
        Absolutely, yes.
        • hellcat
          • Jan 2012
          • 132
          This is a patch reading error. As everyone before has said it does need a drum replacement.
          As you can see in the picture your OPC is worn down to the metal on the side and greatly worn through that small patch you see on the drum. This patch is what is read by the sensor above it. If its worn down it can not properly calibrate itself. Be sure to remember to run Sim 44-2 and 24-11 drum rotation clear to make sure your calibration stays in good shape.
