MX5000
  • DINGO
    • 661
    MX5000
    Hi friends
    I m around two mx5000n that the prtints/ copys , not fuse the toner, in some parts of the paper.
    The fusers units seems ok, and the paper is good to.
    Can someone give some help?
    Thanks in advance.
  • Jaws
    • Oct 2007
    • 235
    Re: MX5000
    How many prints does it have on the fuser and on the copier. Can you post an example pic?
    • DINGO
      • 661
      Re: MX5000
      About 150k eachs.
      • Jaws
        • Oct 2007
        • 235
        Re: MX5000
        I don't have a manual on the MX5000, I am guessing it is like the MX5001. The web cleaning unit needs to be changed and the black drum and developer. Your color drums are due at 100K. Not sure how your machine is set, but it should give a code or stop when the web unit has run out.
        MX-31NUSA
        MX-4100N, MX-4101N, MX-5001N
        OPC Drum Unit
        100K/150K
        MX-410WC
        Web Unit
        150K
        MX-310DS
        DV Seal Kit
        100K/150K
        MX-450FL
        Ozone Filter Kit
        150K
        MX-310HB
        Waste Toner Box Kit
        40K
        • DINGO
          • 661
          Re: MX5000
          thanks mate, i know that , but in my case is not the issue.
          t.you.
          • Jaws
            • Oct 2007
            • 235
            Re: MX5000
            If you have two machines doing the same thing, then I would think it is a setting that is wrong for the weight/gloss of paper.
            • seuba
              • Dec 2015
              • 18
              Re: MX5000
              Originally posted by DINGO
              Hi friends
              Thanks in advance.
              sounds like temp is too low or paper type is wrong
              • faxman28
                • 435
                Re: MX5000
                there are 3 different tech tips(covering 3 different series of color mfp) in US . They all refer to toner flaking and/or overtoning. The solution in the tech tips are the mfp has not been calibrated or calibrated correctly. fuser temp issue usually causes smearing of the toner or repeat image on the page , after about 3 copies or so. Over the years I have seen this on HP printers and other mfps and all settings are correct on the device and that the issue was application related. Usually a adobe product , Quark or other Graphics software. The color settings in the software are set to dark(probably not the right term) and it lays to much toner on the page. Sometimes trying different brand of paper or setting machine to heavy paper would help. But the main thing that you can do is make sure fuser has been replaced with new one or rebuilt with new bearings and pressure springs. Calibrate the mfp using either service manual or calibration bulletin. check 25--1 in sim mode if the developers show a value below 128 they may be overtoned.
                • DINGO
                  • 661
                  Re: MX5000
                  Many thanks, friends
