MX 5000 WEB PAGE
  • DINGO
    • 661
    MX 5000 WEB PAGE
    Hi friends
    I know that is possible change the print temp, and paper weight work, in the mx 5000 web page definitions, i already took a look, but do not found.
    Someone knows where is it?
    many thanks
  • Jaws
    • Oct 2007
    • 235
    Re: MX 5000 WEB PAGE
    Under System Setting, Under paper tray settings, you can set paper type
    • DINGO
      • 661
      I m lookyng something for set like, paper 70 grs to 90grs or 90 grs to110grs, is something like this, but i cant found it.
      • ZOOTECH
        Senior member of CRS
        • 3375
        Have you checked under "System Settings" > "Device Control" > "Fusing Control Settings" > "Set Paper Weight for Fusing Control"?; two choices - either 16-23 lbs, or 23+ -28 lbs.
        I have been setting up both color and b/w machines at 23+ -28lbs with good results.
        • Toner Boy
          • Aug 2007
          • 359
          For heavier paper it would be best to dedicate a tray for 'Heavy Paper 1' and instruct user to specify tray and paper type Heavy Paper 1 in printing preferences through print driver. This will heat up the fuser to appropriate temp for that specific tray in use. Heavy Paper 2 is the thickest/hottest paper setting and will slow down the print engine for better fusing, only can use the Bypass tray for this type paper.
          Standard paper can be used (up to 28lbs with settings described by ZOOTECH in standard trays with no paper type alterations - actually I thought it was only up to 24lbs but may vary by model).
          In service mode you should be able to specify temp settings for each tray (?), but messing with the default settings is not something I can recommend.
          • Jaws
            • Oct 2007
            • 235
            Heavy paper 1 is for 28 lbs to 110 lbs (106 g/m2 to g/m2)
            Heavy paper 2 is for 110 lbs to 140 lbs (210 g/m2 to 256g/m2)
            • DINGO
              • 661
              Many thanks friends.
