SHARP MXC402SC LSU NOISE
  • copydocinc
    • Mar 2015
    • 263
    I am getting a whining noise during printing and if I just lift up the adf.
    The noise goes to a high pitch, then slows down and goes away until I either lift up the adf or copy or print.
    It sounds like some hp printers do when the polygon motor is going out.
    Is this a known thing on this model?
    Can the polygon motor be removed and oiled to fix or is it too well sealed for that?
    and
    How do I get the LSU out?
    The manual really is lacking on details on this.
    It looks like it is accessed from the left side of the machine and a couple thing have to be removed to get to it, but
    I'm hoping for a little extra info, before I try to tackle this one.
  • mansart
    • 852
    Re: SHARP MXC402SC LSU NOISE
    Yes manual is pretty light on remove instructions. But is relatively easy.
    Yes on left side. Couple boards and a fan if I recall correctly
    Would not try to oil.
    Motor available as RMOTP0987FCPZ
    • skookumchuck
      • Feb 2012
      • 62
      The bearings in the LSU motors are mostly air bearings and don't require lubrication. However, I have seen posts on other sites that say they have had some success, at least temporarily, with a tiny dot of very light oil. I never do that, I just replace the entire LSU unit. The are relatively inexpensive these days and then you move on.
      • ZOOTECH
        Senior member of CRS
        • 3375
        Before removing the LSU, mark where the v-notch is on the adjustment plate.
        • ZOOTECH
          • 3375
          My mistake, the adjusting plate does not need to be removed when removing the LSU.
          • jp74msj55
            • Oct 2014
            • 149
            Make sure you leave waste container out before reinstalling!!!!
