Print speed Sharp MX-M1054
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Hi to everybody !
    I show my problem: I have a Sharp MX-M1054,that is slow when it's printing in duplexing mode in A3 size.....
    I don't know if the fault is in the setup of print driver (quality type, finishing etc).
    So, I ask how to set up the driver commands for greater printing speed.
    Another question: how to decrease the percentage of toner (to save power)?
    Thanks ! ! !
    • 23009
    Re: Print speed Sharp MX-M1054
    So when you are considering the slow print speed, are you taking into effect:
    1) what network speed, 10/100/1000 MBs?
    2) that print speed is calculated based on A4 single sided images, so an A3 duplexed image will take 4 times longer to print?
    3) what application(s) are you printing these documents from? DOS based, embedded PDFs, substitute PDF reader?
    4) wireless network?
    We'll need a lot more details. =^..^=
