Sharp MX paper size in trays not detected
  • Jack79
    • Jul 2014
    • 312
    Hello
    Sharp MX-3100n do not detect paper size in trays. It works fine when I manually change paper size under tray setting option Is it any sim which should be performed to adjust it or it can be different kind of problem?
  • rufio311
    • Jun 2013
    • 12
    Re: Sharp MX paper size in trays not detected
    What tray or trays are you referring to? (Tray 1, 2, 3, 4, or bypass tray)
    • jp74msj55
      • Oct 2014
      • 151
      Originally posted by Jack79
      Hello
      Are you doing this in system settings?
      • travi
        • Jan 2008
        • 129
        Trays 1 and 2 of the MX3100 do NOT have auto size sensing. You have to manually set the paper size for them in the system settings. If there is a desk unit with a 500 sheet tray attached, Trays 3 & 4, They wiill have auto size sensing.
        • Jack79
          • Jul 2014
          • 312
          That' s strange. I am sure I have seen Sharps MX-2301 MX-2600 MX-3100 without Trays 3 & 4 and they detect size automatically. Anyway thank for that info.
