Sharp ARM 207
  • logrady2331
    • Feb 2011
    • 301
    Sharp ARM 207
    Hello all, I have a Sharp ARM 207 that will no longer recognize the lower (optional) paper tray. The customer moved the machine when they bought a new house and now the lower tray is not seen by the main body. Any tips?
  • spanky
    • Sep 2012
    • 468
    Re: Sharp ARM 207
    Was the second tray attached to the copier with the brackets and screws.
    If not they may have lifted the machine off of the lower tray and the connector between the tray and the engine became disconnected.
    • logrady2331
      • Feb 2011
      • 301
      Re: Sharp ARM 207
      Thanks spanky!!! You were right. Went back today and they had moved it themselves and sure enough the connector was unplugged. They bent a few pins on the MPCB but I straightened them out and - BAM - works like a champ. Thanks again
        • 23008
        Re: Sharp ARM 207
        Congratulations on your success. =^..^=
