MX2310U Pulling Developer
  • schotschen
    • Nov 2011
    • 33
    The Deveoloper Units are only half full with Develoer.
    So what was going wron? I dont want to buy new Developer
    and in a few Month the Problem is still the same...
    Never seen this on any Pastell Maschine before.
    And i have a lot of them in the Field.
    Iam sorry for my bad english!
  • MdangerP
    • Sep 2014
    • 45
    Re: MX2310U Pulling Developer
    Could be the laser unit. Are there bands of developer on the drums? Is there developer in the waste box?
    • schotschen
      • Nov 2011
      • 33
      Yes! Developer is in the Waste Box!
      • Silviu
        • Jan 2016
        • 17
        Calibrate the LSU and check the sponge on the waste if it is presed to much it can cause you problems a second ground witch will suck all your dev in the waste box
        • coopers1305
          • Nov 2014
          • 49
          Just change out the process unit and your developer issue will be fixed. You could maintenance the process unit but the problem could come back.
          • ayeright
            • Feb 2011
            • 74
            Your charge units are arcing, most likely contaminated with toner. Just posted a similar answer on another thread but with effectively no charge on the drum surface, the dev gets stripped off the cylinder, onto the drum and then cleaned off into the waste box.
