F1-21
  • Sharptech56
    • Feb 2016
    • 100
    [Error Code] F1-21
    error during finisher swap
  • TechGeek
    • 158
    Re: F1-21
    I just recieved a mx-m475 I purchased from an off lease equipment broker. After unpacking and plugging it in I am getting the same error F1-21. I have the RB22 and FX10. The error code says it is a fan problem but there are no fans on either of the RB22 or FN10 that I can find.
    We're you able to find a fix?
    • austonrush
      Sharp & HP Tech
      • 234
      Re: F1-21
      F1-21 Finisher fan trouble
      Section PCU
      Cause
      Finisher fan motor trouble.
      Finisher control PWB trouble.
      Harness and connector connection trouble.
      Check & Remedy Use SIM3-3 to check the operation of the fan motor.
      Check connection between the finisher control PWB
      and the fan.
      Replace the fan.
      Replace the finisher control PWB
      There is a fan in the Transport Section
      • r3d343420
        • Aug 2012
        • 55
        Re: F1-21
        Firmware update
        • mojorolla
          The Wolf
          • 2616
          Re: F1-21
          I agree with the previous post. There are 5 or 6 different firmware packages for the same finisher on different models....
          • ICEuk
            • Oct 2017
            • 9
            Re: F1-21
            Have you done firmware update?
            • tomislav.knezic
              • Apr 2019
              • 3
              Re: F1-21
              Originally posted by r3d343420
              Firmware update
              Hi,
              How can I update finisher firmware? Through simulation 49 or?
              Regards
              • ICEuk
                • Oct 2017
                • 9
                Re: F1-21
                [QUOTE=tomislav.knezic;744955]Hi,
                Regards
                Yes normal firmware update through sim 49. It will update everything.
                • tomislav.knezic
                  • Apr 2019
                  • 3
                  Re: F1-21
                  [QUOTE=ICEuk;744964]
                  Originally posted by tomislav.knezic
                  Hi,
                  Regards
                  So, firmware of the machine and finisher through sim 49-1?
                  I'm asking twice because machine and finisher firmwares aren't in the same file.
                  Regards,
                  Tomislav
                  • ICEuk
                    • Oct 2017
                    • 9
                    Re: F1-21
                    The sfu file has all firmware combined. There is no separate firmware. 49-01
                    • tomislav.knezic
                      • Apr 2019
                      • 3
                      Re: F1-21
                      It is all in the sfu file of the machine firmware? Didn't know that.
                      Thank you!
