MX2301n
+ More Options
Posts
  • mutumoja
    • Mar 2015
    • 12
    [Jamming] MX2301n
    Random Jamming whilst doing multiple coping through the duplex unit only jam code APPD_1, already have removed exit assembly and checked both the sensor arms and Sims operation,but problem persists intermittently whilst duplexing
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: MX2301n
    It wasn't this model, but I did have a new set-up that the duplex motor on the right side door would sometimes reverse it direction, and cause this same code.
    • JR2ALTA
      • Feb 2010
      • 2030
      Re: MX2301n
      Does that exit assembly have a oneway?
      • mutumoja
        • Mar 2015
        • 12
        Re: MX2301n
        have had the assembly out and all bearings are ok thanks
        • mutumoja
          • Mar 2015
          • 12
          Re: MX2301n
          Sorry everyone I have solved the problem.just forgot to post again
          Problem was the sensor arm in the gate leading into the duplex unit which was heat affected and had deformed to a point that it was touching the chassis of the gate thus slowing the reaction time of the sensor reaction causing the intermittent jam.
          Thanks guys for the suggestions
