Sharp AR-M236, black lines
  • Hansoon
    • Sep 2007
    • 3370
    Sharp AR-M236, giving heavy black lines across feeding direction. (see attachment) I'm a KonicaMinolta guy and have no experience with these Sharp beauties. I suspect drum unit or HV but don't want to throw parts at random at this very old machine. Any hints, based on your experience please?
    Thanks in advance.
    Hans
    SCAN-C-353-16040113180.pdf
  • dwarf
    • Oct 2012
    • 168
    Re: Sharp AR-M236, black lines
    clean it good...check the cleaning blade... sure looks like it could be a bad drum... check the fuser as well...
    • walterman
      • 196
      Judging from your washed out image , I would suspect the copier is well beyond its 75k PM. I would look at the drum unit for wear spots along the edges, chances are that is where your black lines are coming from. Check your counts in Simulation 22-6, that count is based off of the last time they were changed, hopefully, the last tech changed the drum and developer when they cleared the counts. I would start with a good cleaning, paying attention to charge corona unit and transfer roller unit on right jam door, clean all contact points, then a drum, cleaning blade and developer change, if needed.
        • 22997
        It's at lest the drum, and probably a lot more. The last time I quoted a full PM it came in around $600 US. That going to be a hard sell on a very old copier. =^..^=
        • SwisSeV
          • Jan 2016
          • 307
          These old machines are my bread and butter right now. We actually have some that are still on a service contract.
          Can't tell everything from looking at one copy. The machine is going to be a mess on the inside.
          Looks like it needs new Developer, drum, charge unit and fuser.
          Quote for a PM and a fusing unit.
          • Hansoon
            • Sep 2007
            • 3370
            Thanks guys.
            Hans
