mx 700 calibration failed
+ More Options
Posts
  • ice
    • Apr 2016
    • 6
    can someone help me with mx7000 copying calibration, I cant calibrate in either I run it in simulation or in the system I already cleaned the glass, mirrors and optics still no success, calibration failed is showing the copy quality is not good
  • SwisSeV
    • Jan 2016
    • 307
    Re: mx 700 calibration failed
    We need more info.
    You say copy quality is bad, is print quality good?
    What adjustment is failing? What is the SP. number you are running? What adjustment are you using through the UI?
    Lastly, what do the copies look like?
    • ice
      • Apr 2016
      • 6
      the machine is not connected to the network it is only use as a copier but for self print i think its good, I did sim 46-24 and auto calibration in the settings but it ends up failing telling to put the test patch in the flatten glass i did check if I place the test patch correctly and still the same result
      the color is too strong yellow turn to orange while orange turn to red its like there is no half tone or something like that
      • ZOOTECH
        Senior member of CRS
        • 3375
        Have you followed the calibration procedures? TC 46-74 is the auto calibration for both the copy and print.
        PM me, and I'll set you up with the sequence for the calibration - thanks to our friend down under?
        Eight more days till retirement.
        • dwarf
          • Oct 2012
          • 168
          make sure that you have cleaned the MFP...then run 50-22 (skew)...the color image sensor calibration is 44-13; also run 44-2, 44-6, 44-26... then run 46-24...
          • ntbann
            • Jan 2012
            • 626
            Dwarf you forgot the 44-27 before 44-6 and 44-26.
            • ice
              • Apr 2016
              • 6
              thanks a lot guys ill try to do all of this later, and some person also told me to reset some data's thru simulation before doing the calibration..? i don't know ill find out later
