Sharp Developer Unit
+ More Options
Posts
  • Jack79
    • Jul 2014
    • 312
    Hello is it possible to fix developer unit which cause lines on prints?
    Picture shows light line on the roller on left side of picture which is printed on the colour page. Drum is fine.
    What cause this kind of problem and how to fix or correct it please?.
    Regards
    Jack
  • spanky
    • Sep 2012
    • 468
    Re: Sharp Developer Unit
    you have debris or a toner clump blocking the developer flow on the mag roller.
    Run sky shots in each color to see which one has the blockage.
    Remove that developer unit and using your tool turn the mag roller, while doing this use a feeler gauge or a small piece of paper to go between the mag roller and the doctor blade and push the blockage to the side of the mag roller where it is out of the image area.
    • ice
      • Apr 2016
      • 6
      yap! hes right try cleaning the dv unit some object is blocking the developer from going up try using a vacuum if you have but try to keep the developer aside first so you can pour it back after cleaning the dv unit
        • 22989
        Make yourself one of these:
        • Jack79
          • Jul 2014
          • 312
          Thanks for that. This trick works well.
          What is the SIM for printing each colour separately (mx-2600)?
          • SwisSeV
            • Jan 2016
            • 307
            If you want to print a total background color you can use,
            1. SIM 61-1
            2. Test pattern 17
            3. Select color
            4. Print
            • spanky
              • Sep 2012
              • 468
              You dont need to run a sim. Run sky shoots in the single color mode and run one in each color of cyan, magenta, yellow, and black.
              • skookumchuck
                • Feb 2012
                • 62
                Good idea on the custom mylar tool. I use business cards.
