MX2314 firmware problem
  • ice
    • Apr 2016
    • 6
    [Dead] MX2314 firmware problem
    can you help me with my problem
    I have Updated the firmware for MX2314 from u101g2 to u300g2 after that the screen went white you will just see the sharp logo at the start then afterwards all white, I tried to manually update it with the use of dip switch but it cant read my file on the usb it tells "data error"
    is there any way to return it to its original firmware u101g2 or do i have to replace the SDcard
  • coopers1305
    • Nov 2014
    • 49
    Re: MX2314 firmware problem
    I'd replace the SD card. I had this problem on a MX-4101N. Unless you have the wrong firmware due to DSK or something.
