Sharp MX M363 Copy Quality grey (where should be black)
  • Doug James
    • Jan 2012
    • 935
    [CQ] Sharp MX M363 Copy Quality grey (where should be black)
    This copy is basically lighter than it should be... I changed the developer and drum and blade. I cleaned the optics and laser lens...
    Not sure where to go from here really... Any help would be a great help... Thanks so much
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Sharp MX M363 Copy Quality grey (where should be black)
    the whole page or just the the top or bottom? the top/bottom being light is likely the doctor blade being off
    • Doug James
      • Jan 2012
      • 935
      The whole page is off.. I will check the developer housing today... I will post a picture today.. Thanks so much for your reply !!
      • spanky
        • Sep 2012
        • 468
        run a test print like sim 64-4 that has solids blacks and see if they are also light.
        • ntbann
          • Jan 2012
          • 631
          This has work for me. run 44-27, 44-6, 44-26 then run the 46 calibration sim. Also is drum blue or green?
          • copyguy1
            • Jul 2011
            • 142
            Make sure the machine is not it toner save 46-19. And the other possability waould be a laser issue
