5141 U2-91
  • Madnhain
    • Dec 2012
    • 148
    5141 U2-91
    This machine is a bastard. It has had a number of issues, All PWB's have been replaced, All EEPROM have been reprogrammed and replaced. New SD card and Flash ROM. Machine persists with U2-91, cannot enter SIM to cancel code. Tried leaving door open to no avail. Sharp support is scratching their heads, Any ideas?
    Thanks!
  • JLSam
    • Jun 2015
    • 605
    Re: 5141 U2-91
    Thanks!
    So... all PWB's are replaced. Including EEPROMS too? Jesus...
    So, after doing a bit of research. There is an urgent service bulletin for replacing these EEPROMS, please see attached file.
    Remember, it is impossible to clear the โ€œU2 Trouble Codeโ€ by executing Sim. 16, unless the EEPROM is initialized, and you need to be... hyper careful in the handling of those EEPROMS.
    You can not even put the EEPROMS in styrofoam because it can generate static.
    • Madnhain
      • Dec 2012
      • 148
      Re: 5141 U2-91
      Yes, I am familiar with the EEPROM replacement procedure, thank you.
      The only thing I've come up with is a possible DOA PCU PWB. I have a replacement on order.
      • igi
        • 1507
        Re: 5141 U2-91
        ok i had a similar issue.
        try the following.
        1-go to same model machine with the usb stick back up all the eeprom data .
        2-deploy data from the stick on the troublesome machine.
        Good luck
        • Madnhain
          • Dec 2012
          • 148
          Re: 5141 U2-91
          try the following.
          Good luck
          I can't enter SIM mode
          That's an interesting idea. I hadn't thought of that.
