Sharp mx2640 & condensation
  • Leebs14
    • Feb 2014
    • 457
    [CQ] Sharp mx2640 & condensation
    Ok I've seen a lot of things servicing copiers over the years but I've never seen this
    I got a call to look at a 2640 which was fine when printing but when scanning or copying its smudged!!
    I couldn't find anything wrong with it when I arrived and tested it the customer says it gets worse the more you copy or scan, so I put 50 originals in the doc feed and copy them, after I had done this 3 times (150 copies) it started smudging and got worse and worse.
    When I lifted the doc feed up to my surprise the glass was coated in condensation, I took the glass off and I could write my name on the mirror and underside of the glass!! I cleaned everything and it copied fine again but after 200 single originals it was back!
    It's in the back office of an estate agent, it's an old building and a bit dingy but it's cool and didn't seem any worse that other places I've worked in.
    Anyone seen this? Any ideas guys??
  • tee
    • Aug 2014
    • 79
    Re: Sharp mx2640 & condensation
    I would try a dehumidifying heater for the scanner.
    part # dkit-0427fc11
    • SwisSeV
      • Jan 2016
      • 307
      Re: Sharp mx2640 & condensation jjj
      I see that all the time. Sometimes there is way more humidity than you would expect. Having a Thermo-Hygrometer Pen takes the guess work out of it. I wish I had one. Although where I live, I just assume the humidity is too high.
