Re: mx 3100n z fold
I do have POD2 N jams ,i will have a look at it when i'll get back there (1 hour away from the shop ).
Thanks for the input.
mx 3100n z fold
Re: mx 3100n z fold
Remove primary transfer belt and check the main drive gear. Remove the gear as you will not see the damage without removing it. The plastic where the shaft pin sits in shatters, causing the transfer belt to stall intermittently, and will cause POD1_N fuser entrance jamsLeave a comment:
mx 3100n z fold
Mx 3100n jam z-fold at the entrance of fuser once in a while (1 out 50),feels like the fuser doesn't start, anybody have a clue ??Tags: None
