MXM 450n
  • foudl
    • Mar 2010
    • 138
    [Jamming] MXM 450n
    PPD1_ST1, is it related to the ps roll unit or the rollers of the 1st cassette??
  • SwisSeV
    • Jan 2016
    • 307
    Re: MXM 450n
    ppd1_st1 = Paper in tray one and stopped over ppd1.
    • foudl
      • Mar 2010
      • 138
      Re: MXM 450n
      Then should i change the ps roll unit to fix the prob. ??
      • SwisSeV
        • Jan 2016
        • 307
        Re: MXM 450n
        If it is only jamming from tray one, I would start with inspecting the feed/ pickup rollers and the tray itself.
        • SwisSeV
          • Jan 2016
          • 307
          Re: MXM 450n
          If that's not it my next guess would be a worn out delivery roller that is slipping.
          • copiertec
            • Jan 2016
            • 2188
            Re: MXM 450n
            I'm assuming you have checked the obvious, tray 1 p/u, sep and feed rollers. I'm assuming you have tried feeding from tray 2, tray 3 or MP tray to see if the problem occurs. I'm assuming you have cleaned the ps roller and the sensor. If you have done all of the above to no avail, I would change out the ps unit.
              • 22996
              Re: MXM 450n
              Something like this?:
              Misfeeds (jam code TRAY1). After rollers are changed jam code changes (jam code PPD_ST1), after running pre-perforated cardstock & repeated jamming. Tray #1 lower separation guide is broken at its front swivel. Remove the print engine. Remove these units: drum, developing, cleaning, registration. Flip engine upside down. Remove left cassette rail to install the tray #1 lower separation guide (PGIDM1892FCZZ).
