Re: Sharp AR M350N toner problem. two new toners and still says "check the toner cart
Blackcat is exactly right there, check the DV unit for seizing and if ok clean out all developer and change with new developer then recalibrate. If that doesn't correct it then you may be looking at a bad board but I have had these problems on that model and never was it a bad board.
