mx 5070
  • rainmaker
    • Jul 2011
    • 77
    mx 5070
    have a Sharp MX5070 that while idle will go into a jam.The jam code is FIN_ERR.which as sharp says it is a communication jam.I have replaced the Finisher board and the PCU and did firmware.You can open the left door and close it and it resets.Sometimes if you send a print job it will sit and sit till you open the right door and close it.I even checked the jam sensors took a picture of what is normal as sensor are on of off and compaired to what I took.It is not a sensor jam,meaning no difference in sensor normal or when it shows a jam.Sharp is no help on this.we are a dealer,just wanted to see if anyone has this issue with FIN_ERR.thanks
  • spanky
    • Sep 2012
    • 468
    Re: mx 5070
    I have found finisher communication issues can becaused by the actuator for the top tray position sensor not moving fast enough. I move the sensor a little closer so theactuator is required a smaller movement between on amd off.
    • harleyrider
      • Oct 2011
      • 348
      Re: mx 5070
      Did you find a fix for this? I have a MX6070n doing this also. Thanks
      • rainmaker
        • Jul 2011
        • 77
        Re: mx 5070
        the sd card.i believe that was it
        • boobookitty
          • Nov 2016
          • 6
          Re: mx 5070
          5070 doesn't have an SD card. Maybe you meant mSATA?
          • rainmaker
            • Jul 2011
            • 77
            Re: mx 5070
            yes sorry it was the msata ssd
            • harleyrider
              • Oct 2011
              • 348
              Re: mx 5070
              Weird thing on mine is I switched finisher with one from shop and both machines and finishers have been working fine since. Bad news I need to switch them back out. Sharp says connections and firmware.
              • gmoore081
                • Jun 2018
                • 14
                Re: mx 5070
                Hi All
                I'm glad I have found this thread on here. I have a Phoenix with the same error code which is very intermittent & I'm finding impossible to replicate when onsite. Is the msata the cause for this?
                Thanks for your help in advance
                • mickj
                  • Apr 2015
                  • 33
                  Re: mx 5070
                  I had same problems and it was the finisher harness just like I had years ago on ricoh machines and seeing this is a ricoh finisher same old problems still to this day
                  somethings just never change lol
                  • joe_vanacker
                    • Dec 2016
                    • 28
                    Re: mx 5070
                    Can you tell me what you changed on the finisher harness (where, what?)
                    • boutn
                      • Jun 2016
                      • 547
                      Re: mx 5070
                      Got the same here on a mx4070
                      anyone got any tips?
                      What harness for example?
                      thx in advance.
