SHARP MX 364
  • simonsays
    • Aug 2013
    • 95
    SHARP MX 364
    this machine will print a report but when trying to make a copy says waiting anyone ever see this and it's not the hard drive no error codes in the report
  • driving lots of miles
    • Jun 2016
    • 399
    Re: SHARP MX 364
    The only time I have seen this is because of a bad print job holding things up or the copier is looking for a different size/type paper than is in the machine.
    • SwisSeV
      • Jan 2016
      • 307
      Re: SHARP MX 364
      Bad memory could cause this. Sim 60 to do a quick check.
        • 23009
        Re: SHARP MX 364
        When this happens on Canon MFPs it usually means that the exposure lamp is not reaching the proper intensity. The copy paper sits and waits at the registration roller for quite a long time, the machine displays "Copying", then eventually shows as a paper jam, but it's not a paper jam. The scan lamp never reaches intensity, and the original is never scanned. It can be because the lamp ends have blackened, the environment may be very cold, lamp contacts are arcing, lamp heater has failed, or lamp heater has rotated to cover the intensity sensor.
        I cannot honestly say if that's what's happening on a Sharp though. =^..^=
        • techwurk
          • 127
          Re: SHARP MX 364
          Probably the memory chip bad, had the problem
          When I started servicing copiers they used toaster ovens for fusers.....I'm old
          • simonsays
            • Aug 2013
            • 95
            Re: SHARP MX 364
            never feeds paper at all not at reg roller not out of tray just says waiting
            • spanky
              • Sep 2012
              • 468
              Re: SHARP MX 364
              Disconnect the network and fax cables.
              Cycle the main power to the machine.
              Run sim 66-10 to clear the memory.
              Try making a copy, if you can copy then reconnect the fax cable.
              Try making a copy, if you can copy then reconnect the network cable.
              If unable to make a copy after reconnecting the network cable you have a bad print job coming in or something on the network is sending something other than a print job to the IP address of the copier.
              • simonsays
                • Aug 2013
                • 95
                Re: SHARP MX 364
                it was the board not memory
