MX1810U boot message
  • glimmer1980
    • Aug 2014
    • 105
    Hi,
    Does anyone know what the below message on a MX1810 would cause
    Version check ICUB: W100G100
    The MFP won't start after this message
    Regards,
    Ramon
  • copyguy1
    • Jul 2011
    • 142
    Re: MX1810U boot message
    Sounds like corrupt firmware. Try to do emergency update
    • faxman28
      • 435
      Originally posted by glimmer1980
      Hi,
      Regards,
      Ramon
      make sure the fw update switch on mfp control bd is off, that screen can come up when update switch is on(some call it emergency fw update). If the switch is off and you don't see the sharp boot screen , the sd card needs replacing as the boot program is on the sd card.
      This function is used to revise the firmware by using the USB memory
      for the MFP PWB, the SCU PWB, the PCU PWB, the FAX
      PWB, and each option.
      It is basically same as SIM 49-01, but differs in the following points.
      1) The update target ROM is automatically selected.
      2) When the power is shut down or an abnormality occurs in a
      section other than the boot program for some reasons during
      firmware update operation of other method than the CN
      update.
      If, however, an abnormality occurs in the boot program, this
      method cannot be used. On that case, the SD card must be
      replaced with a new one having the normal boot program.
      When the boot animation is displayed but "Copying is enabled" is
      not displayed on the copier basic menu, there is an abnormality in
      the main program (SD card).
