MXM450N
  • foudl
    • Mar 2010
    • 138
    [Jamming] MXM450N
    MXM450n jam in duplex,it will do a certain amount of copies (around 10) , jam code ''tray 1'' ,even if i use the 2nd tray the jam code is Tray 1 , the paper stop at the exit of adu right before it gets to ps unit. And there is no paper anywhere else
    Thanks for the inputs
  • nottoosharp
    • 266
    Re: MXM450N
    Clean the optical sensors
      • 22996
      Re: MXM450N
      I have a few database entries:
      Misfeeds (jam code TRAY1). After rollers are changed jam code changes (jam code PPD_ST1), after running pre-perforated cardstock & repeated jamming. Tray #1 lower separation guide is broken at its front swivel. Remove the print engine. Remove these units: drum, developing, cleaning, registration. Flip engine upside down. Remove left cassette rail to install the tray #1 lower separation guide (PGIDM1892FCZZ).
      Misfeeds (jam code TRAY1). Customer has loaded used stapled packets of paper in tray #1. Load new, unstapled paper into tray #1.
      Misfeeds (jam code TRAY1). Customer has loaded paper folded over at the bottom of tray #1. Load new flat paper into tray #1.
      Misfeeds (jam code TRAY1). Paper krinkles in tray #1. The customer has removed the paper guide in front of the feed tire assembly in tray #1. Replace the paper guide (PCOVP1543FCZZ).
      • JR2ALTA
        • Feb 2010
        • 2030
        Re: MXM450N
        Boy, that doesn't sound right. Tray 1 Jam is very specific to paper not leaving Tray 1...
        • foudl
          • Mar 2010
          • 138
          Re: MXM450N
          That's the point ,it's a bit weird but even if i use tray # 2 it will still jam with jam code ''tray 1'', could it be related to the drive unit ??
          • nottoosharp
            • 266
            Re: MXM450N
            Is the exit gate for tray one missing?
            • lky1978
              • Mar 2009
              • 482
              Re: MXM450N
              suggest to check/replace tray one feeding clutch.Or better replace gear box unit.
              • foudl
                • Mar 2010
                • 138
                Re: MXM450N
                So the drive unit (or gear box) is suppose to control the 1st tray ?
                • nottoosharp
                  • 266
                  Re: MXM450N
                  The feed cassette is easy to swap out. Post a photo of the machine with the side covers open
                  • lky1978
                    • Mar 2009
                    • 482
                    Re: MXM450N
                    Yup. The main drive unit (here we call gear box unit) ,got a clutch to control 1st paper tray feeding.
                    • nottoosharp
                      • 266
                      Re: MXM450N
                      We call it a drive pack.
