sharp mx5001n emergency download
  • clark
    • Sep 2016
    • 109
    I got a couple of 4101 and 5001n and they had been erase. I have the firmware on usb. but it says error in downloading the info. I did rename file and no luck. and rom error also. Any help would be nice. I have been working on these sharp for over 20years. I cant get into the service area. I have to do it from turn on the machine. Thanks for any help. clark
  • nottoosharp
    • 266
    Re: sharp mx5001n emergency download
    The only file that can be on your USB is the firmware so you have to open up the folder and just get the firmware file the FSU file that's the only thing that can be on the USB drive then you need to pull out the main board and flip the DIP switch in order for that to boot to USB.
    • nottoosharp
      • 266
      Additionally you need to check to see if there's a security data kit on the machine that you're working on if so you need to make sure that you download an SDK firmware file and again the only thing that can be on the flash drive is just the file
      • clark
        • Sep 2016
        • 109
        Don't know it there is data security on machine. I just loaded the 1 file for firmware and all I get is data error. I did rename file emupdate_j2.sfu and still no luck. any thing else I should try. Thanks
        • ZOOTECH
          Senior member of CRS
          • 3375
          Two different files if it has the DSK or not.
          • driving lots of miles
            • Jun 2016
            • 399
            Did you unzip the file from the download?
            • clark
              • Sep 2016
              • 109
              The file I have is un zip. I'm thinking I have the wrong file for this machine. It say on the jump drive firmware and data security. I removed the firmware to another jump drive just the firmware and no luck.
              • mttech
                • Mar 2014
                • 127
                Go into sim22-10 and find security. If it says none you need the basic firmware for MFP, if it says it has a DSK you need to download the firmware for that DSK.
                • clark
                  • Sep 2016
                  • 109
                  Cant go to simms. The machine is in emergency load only. Any other thoughts. Thanks
                  • nottoosharp
                    • 266
                    Did you flip the dip switch? To update?
                    • clark
                      • Sep 2016
                      • 109
                      NO. This is new to me. And where is this switch? Thanks
                      • nottoosharp
                        • 266
                        Slide the main board out of the right rear of the machine there will be two tiny switches at the top above the sd card. One will say update. Flip to update. Insert USB flash drive into slot and power up machine. Then use menu to select firmware update
                        • clark
                          • Sep 2016
                          • 109
                          Thanks but no luck. turn on switch and tried download and say data error. it also says unusal rom error. I cant think of anything else to do at this point. Thanks
                          • nottoosharp
                            • 266
                            Don't try to write rom. Hit menu then up until it says firmware update in upper left corner
                            • clark
                              • Sep 2016
                              • 109
                              I was in firmware update. and when I press start all it says is data error. thanks
