Why is sharp tech support so grumpy?
+ More Options
Posts
  • qbert69
    • Mar 2013
    • 1152
    #16
    Re: Why is sharp tech support so grumpy?
    Originally posted by subaro
    I only call tech support once in a blue moon. If my boss suggest i call tech support, i reply that i am tech support, as the other side is usually on a different Mhz. Of all the support i have used, Kyocera are the best, they are prompt, knows their stuff and also have a Q&A site that you can log calls if you don't have the time with the phone. log the call when you get a chance and check back later for the reply.
    Also i may add, kyocera service website are instant access, and downloads are super fast. i can open manuals right on their site and browse easily. Make the switch guys, it's worth it from a service point of view.
    Saying the moon was blue was equivalent to saying the moon was made of green (or cream) cheese; it indicated an obvious absurdity. In the 19th century, the phrase until a blue moon developed, meaning "never." The phrase, once in a blue moon
    If you notice about the newer "02" series Kyocera TaskAlfa machines, they've pretty much made all the PM maintenance "tool-less"!...fuser pops out!....rear panel...one screw at top left corner....unscrew, slide panel off!....paper feed units unclip and slide out to replace feed tires! Beats the SHIT out of RICOH!....the "other" brand we work on....the "red-haired" step-child in the corner of the room!
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
