Sharp MX6240N MX-FN19 Misfeed
  • buzz
    • Aug 2013
    • 288
    On Power up, Machine displays "misfeed occurred" in the finisher. Checked Sensor switching FED paper inlet ...etc. in simulation mode. Machine does not clear the jam indication unless I restart the copier. Updated to current firmware.
  • buzz
    • Aug 2013
    • 288
    Re: Sharp MX6240N MX-FN19 Misfeed
    ****UPDATE*****I ended up removing the Punch unit, and now the misfeed error on start up is gone. I think one of the sensors in the Punch unit is bad or blocked.
    • spanky
      • Sep 2012
      • 468
      There are two pwb boards in the punch unit, one is an LED PWB the other a transistor PWB. They are at the entrance and are used for edge detection and jam detection. I replace these often for such issues.
      • buzz
        • Aug 2013
        • 288
        Thanks Spanky, you change these out as a set?
