Scan to SMB for Windows Server 2012 R2
  • samyeh
    • Oct 2015
    • 16
    Dear All,
    Please help me to configure scan to SMB for Windows Server 2012 R2 step by step?
    I know Sharp MFP cannot support SMBv3, so how to solve the issue?
    Thank you very much.
  • qbert69
    • Mar 2013
    • 1152
    Re: Scan to SMB for Windows Server 2012 R2
    Check your port number on the MFP that is used for scanning to SMB...I think Windows server 2012 R2 uses port 445 instead of 139. Make sure your MFP uses port 445 for scan to SMB!
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • samyeh
      • Oct 2015
      • 16
      Thank you very much for your kind reply,but still cannot use it!!
      • spotlifter
        • Mar 2008
        • 65
        The Old way - Install Sharpdesk.
        The complicated way - https://support.microsoft.com/en-us/kb/2696547
        (I don't know this link will help you or not but hope it lights up some ideas.)
        sigpic
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Scanning to local FTP could also be an option.
          You will need to install an FTP server, e.g. FileZilla, create an authentication user, set the user's home directory as the scan folder, then allow FTP through the firewall. Should only take a few minutes to set up.
          • JLSam
            • Jun 2015
            • 605
            When sh*t hits the fan. Good ol Sharpdesk to to solve the problem.
