MX5070 AirPrint
  • troyofsunday
    • Aug 2015
    • 14
    [Misc] MX5070 AirPrint
    Recently installed a MX-5070 and the customer would like to use AirPrint. I have updated the firmware for AirPrint and made sure that it is enabled. However the machine is not showing up on their Apple devices. They have two HP machines that they can see on the devices however. I have not checked the settings on the HP's to see why they are showing and our new machine is not. I did also turn on the AccessPoint feature on the machine and was able to connect and print to it. Any insight or help in regards to this would be greatly appreciated.
  • ntbann
    • Jan 2012
    • 627
    Re: MX5070 AirPrint
    Are the devices on the same network as the machine? From my experience the apple product will not se the machine if not.
    • troyofsunday
      • Aug 2015
      • 14
      Re: MX5070 AirPrint
      I forgot to mention that they are on the same network as the device.
      • troyofsunday
        • Aug 2015
        • 14
        Re: MX5070 AirPrint
        Went onsite to open a ticket with Sharp. Confirmed that once firmware is updated, air print is enabled and the machine is on the network it is than accessible. Will be setting up a time with customers IT to be on site at the same time to see why it doesnt work.
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Re: MX5070 AirPrint
          If all else fails, you can set up AirPrint on any Windows server, this will enable any shared printer to be used for AirPrint.
          See: https://web.archive.org/web/20160330...ctivation.com/
          • troyofsunday
            • Aug 2015
            • 14
            Re: MX5070 AirPrint
            ruben
            Re: MX5070 AirPrint
            I will keep this in mind. Their IT company had actually setup something like this for the previous machine on site.
            • tmaged
              Owner/Service Manager
              • Oct 2008
              • 1868
              Re: MX5070 AirPrint
              Try to hit the webpage from the device you're trying to print from. That way you'll know if you can in fact get to it.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
              • mansart
                • 852
                Re: MX5070 AirPrint
                Had the exact thing today on a MX4070.......
                Initially machine was wired 192.168.0.50, all workstations could print and scan, both wired and wireless workstations. However no AirPrint. Once I disabled "Wired" and set machine up wireless, then the machine became visible via AirPrint.
                • troyofsunday
                  • Aug 2015
                  • 14
                  Re: MX5070 AirPrint
                  I feel like a fool for forgetting to do this. Last time i was out there that didn't see any of the AirPrint devices from the phone they had me looking at. They verified that they could print to the hp via one of the phones. I will be working out there again in the morning to hopefully get this thing resolved.
                  • troyofsunday
                    • Aug 2015
                    • 14
                    Re: MX5070 AirPrint
                    I will add this to the things to try tomorrow while working with their IT.
                    • troyofsunday
                      • Aug 2015
                      • 14
                      Re: MX5070 AirPrint
                      Was able to get the machine to showup on for AirPrint after making a few changes. We ended up moving the machine to the Wireless setup without any luck. After this we enabled IPP, and IPP-SSL under the AirPrint settings. This made the machine show up on the devices. AirPrint now works.
