MX-2700N with error L4-31
  • axyun
    • Aug 2007
    • 1323
    Getting L4-31 on MX-2700N. Any help is appreciated. Frank/ActionPhotocopy
    • 22997
    Re: MX-2700N with error L4-31
    Do you know what the code means?
    Have you done anything? =^..^=
    • SwisSeV
      • Jan 2016
      • 307
      Cause 1. Fan connector disconnection
      Check the harness and the connector between the
      PCU PWB and the fan.
      Cause 2. Fan does not rotate because of some other trouble.
      Use SIM6-2 to check that the fan is rotation actually.
      Refer to POFM fans
      2700papercoolingfans.pdf
      • JR2ALTA
        • Feb 2010
        • 2030
        Frank
        I would try the trouble reset in simulation mode it may be a quick fix. This is above the fuser so it's a critical fan and will code out almost immediately. The code doesn't say if it's the front or rear fan, so as the previous poster said you may have to watch to see which one is turning and which one isn't. I believe they are removed pretty easily behind the plastic cover maybe you can breathe some life back into the fan with a drop of oil
        • nottoosharp
          • 266
          These fans die. It's a fact. If you have a bone yard pull some fans. I wouldn't try to repair the fan, and honestly I wouldn't piss around and only change one of them. Rather than let your client have a down machine for a few days just spend some cash and get them up and running. After all we make our money off of happy clients. Happy clients pay their bills. Paid bills means happy bosses. Happy bosses don't get too upset when you forget that the train always runs at a slightly different time every morning.
          • sharphead
            • Aug 2009
            • 285
            When you split the delivery unit try to spin the fans by hand. If it spins smoothly its fine. If it judders is dead.
            • SwisSeV
              • Jan 2016
              • 307
              The electronics on the fan goes bad too, you can't tell if a fan is good by spinning it.
              • JLSam
                • Jun 2015
                • 605
                Refer to POFM fans
                [ATTACH]34408[/ATTACH]
                This. I've replaced these fans too often.
                • sharphead
                  • Aug 2009
                  • 285
                  I must have just been lucky on the dozen or so I've replaced.
                  • axyun
                    • Aug 2007
                    • 1323
                    Thank you foral the advice and help. I ordered the fan unit that is connected to the delivery asm with 3 screws. It has the 2 fans in it. Should arrive today. Will post results. Frank
                    • axyun
                      • Aug 2007
                      • 1323
                      Replaced fans and all is well. Thanks again. Frank
