MX5001N no magenta image
  • Dartplyr
    • Feb 2016
    • 11
    [CQ] MX5001N no magenta image
    Ive seen this problem posted here before, with possible solutions. i just can't find it now.
    the magenta toner is stripped from dev unit. i have tried a new developer unit,along with developer and new drum unit. happens every few months. copy volume is low and no problems with other colors.
    your help is appreciated
  • sharphead
    • Aug 2009
    • 285
    Re: MX5001N no magenta image
    Possibly the process electrode cover is cracked.
    • xring1958
      • 166
      We had this happen several times. initially we thought it was a TDC sensor issue then we started replacing DV units. We called it barber poling. We now check drum units for wear. Check the waste toner & see if you have a lot of developer in it ( Use a magnetic screwdriver ). We traced much of our issue to a lazy tech who was resetting drums on PMs instead of rebuilding or replacing them. We Replaced the defective part ( Tech) and issue dropped of markedly. I know you replaced drum & dv but still worth a look at the drum wear.
