Scan to windows 10
  • ZeusGT
    • 271
    Scan to windows 10
    Hello all!
    I am loking for help. I have a customer who is in need of another copier, but he needs the copier to scan to Windows 10. Would a Sharp MX-3110n be a decent choice and would this copier scan to Windows 10? If not, what would be a good copier that would scan to Windows 10? What about Sharpdesk? Does Sharpdesk allow scanning to Windows 10?
    Thank you very much!
    CompTia A+ Certified
    CompTia Net+ Certified
    CompTia Server+ Certified
    CompTia Project+ Certified
    OP Scanshare Certified
  • lopakad1
    • Nov 2014
    • 69
    Re: Scan to windows 10
    sharpdesk works on windows 10 really well. i have had no problem with 3110 on win 10. if you do have a problem u can set up scan to email.
    • onetek
      • 318
      To scan locally, I always find it easier to setup scan to main hdd folder : Enable the NAS function under Network Settings .Also enable NBT/WINS from Security Settings->Port Control.
      Scanning: Scan 2 hard drive, main folder , click :create pdf for pc browsing.
      In your file explorer go to : \\sharp ip address\public\main user=admin, pass=admin
      Works with all operating systems.
      • ZeusGT
        • 271
        Outstanding information guys. Thank you so very much for all the help!!
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2595
          Related note: If experiencing difficulty SMB scanning in W10 then be sure to disable password protected file sharing options.
