sharp mx-2640n w/error code c4-00
  • dcooper
    • Nov 2014
    • 37
    [Error Code] sharp mx-2640n w/error code c4-00
    Hi
    I was wondering if there is a certain procedure to troubleshoot a mx-2640n that has a c4-00 code. if you turn off the main switch and turn back on
    the machine goes in ready mode but when you make a copy paper jams and code c4-00 returns on display. Thanksfor your help.
  • spanky
    • Sep 2012
    • 468
    Re: sharp mx-2640n w/error code c4-00
    Cause
    The PTC unit is not installed properly./Trouble.
    The primary transfer unit is not installed properly./
    Trouble.
    The secondary transfer unit is not installed properly./
    Trouble.
    High voltage TC PWB trouble.
    PCU PWB trouble.
    Connection trouble of the connector and the harness.
    Check & Remedy
    Replace the PTC unit.
    Replace the primary transfer unit.
    Replace the secondary transfer unit.
    Check disconnection of the high voltage TC PWB
    connector./Replace.
    Replace the high voltage TC PWB.
    Replace the PCU PWB
    • nottoosharp
      • 266
      The simple answer to try things out and see if you fix something is removed one component at a time and reinstall it and see if the issue continues. It could be as simple as a poor connection.
      • boobookitty
        • Nov 2016
        • 6
        Replace the high voltage TC PWB. Very common.
        • faxman28
          • 435
          Originally posted by dcooper
          Hi
          there are several bulletins out for c4-00 on the 2640 series. TC pwb was upgraded in sept. 2014 , if your 2640 was made before then , replace tc pwb first. bulletin mfp-tb-1084, the shafts for the clutches that shift the transfer belt were changed, bulletin mfp-tb-1272. It could be the ptc corona unit , but haven't run into that , it's been the tc pwb, shafts and clutches, and primary transfer unit. one of these or a combo of the items.
          • dcooper
            • Nov 2014
            • 37
            Thanks for your advice. I have a tc pwb and those clutches on order. I'm gonna replace tc pwb first then the clutches. Thanks again
            • faxman28
              • 435
              I would also get the clutch shaft mod , this mod adds e rings to the shaft that hold the clutches tighter . e-ring is now on front and back of clutch, holding clutch face tighter to clutch body for less slippage.
              • dcooper
                • Nov 2014
                • 37
                Hi, I have an update. I changed the TC pwb and the copier started working immediately. Thanks for your help!!!
                • austonrush
                  Sharp & HP Tech
                  • 234
                  Originally posted by spanky
                  Cause
                  Trouble.
                  Trouble.
                  PCU PWB trouble.
                  Check & Remedy
                  connector./Replace.
                  Replace the PCU PWB
                  It's most likely the TC-PWB.
                  When the printer jams is there an image on the primary transfer belt or drums? If not, you can pretty much skip all the other steps and replace the board.
