Sharp Ar-M316
  • Service@PRT
    • Oct 2016
    • 181
    Sharp Ar-M316
    morning guys,
    any one have an idea on how to make middle east toner cartridge be able to use with europe version machine of sharp ar-m316?
    the customer machines come from europe, currently we are in UAE and sharp oem toner from middle east is not recognize by this machine.
    any input will highly appreciated.
    thank you.
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
    • 23008
    Re: Sharp Ar-M316
    I can tell you this much:
    The identity of the toner is stored on an EEPROM chip mounted on the rear of the toner cartridge. Either you can purchase new or re-program the EEPROMS. How to re-program or where to purchase EEPROMS? I have no idea. =^..^=
    • nottoosharp
      • 266
      Re: Sharp Ar-M316
      I don't think you can rewrite EEPROMs
      • faxman28
        • 435
        Re: Sharp Ar-M316
        eeproms(Electrically Erasable Program Read Only Memory) are rewritable. Back in the day, copiers and the first MFP's had multiple eproms/eeproms instead of flash memory. dealers had rom burners or had to buy the individual roms from the manufacturer. some machines had 6 plus roms. I would try Alibaba website, they have a lot toner chips and copier parts and toner chip reprogrammers. Search the web for toner chips if it is a popular toner there is some one refilling or generic toner out there that may sell chips or toner.
        • nottoosharp
          • 266
          Re: Sharp Ar-M316
          Thanks for the heads up. Although we've only had to replace one EEPROM in a year so I don't know if it would be worth the expense for us. But it might be for somebody.
          • mansart
            • 852
            Re: Sharp Ar-M316
            What about the "destination code" of the machine? I have never tried but worth a shot
            These are the choices I have in the states. Not sure if there are different options elsewhere
            • nottoosharp
              • 266
              Re: Sharp Ar-M316
              [ATTACH=CONFIG]34821[/ATTACH]
              The destination code is for fuser temperature, not for toner. A good thought though.
              • lky1978
                • Mar 2009
                • 483
                Re: Sharp Ar-M316
                take out the cartridge,RUN SIMULATION data initial 80-09.
                ll appear ERROR message U9-99 after it boot up, and dont worry.Set to ur country destination via sim26-6.
                now put ur local original toner cartdrige (AR-310FT IF I NOT MISTAKE)
                DONT FORGET RUN SIM25-02 BECAUSE UR COPIER SETTING RETURN TO DEFAULT VALUE after U RUN SIM 80-09
                touch panel need to adjust sim 65-01
                document size detector need to adjust sim41
                by pass tray sensor need to adjust sim40
                lead edge adjustment sim 50
                you better record all the settings before run the simulation 80-09
                • Service@PRT
                  • Oct 2016
                  • 181
                  Re: Sharp Ar-M316
                  yes it is AR-310FT, will try this one within the week. will give an update. thanks
