Sharp Mx-2301n Toner Replenishment
  • Service@PRT
    • Oct 2016
    • 181
    after toner replenishment... of newly installed oem yellow toner... says changed toner???
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • lky1978
    • Mar 2009
    • 483
    Re: Sharp Mx-2301n Toner Replenishment
    bad yellow drum, charger, dv
    • aikens
      • Oct 2011
      • 16
      I know it's not much help but I have had bad toners. The chip gets corrupted, try another if available.
      • Service@PRT
        • Oct 2016
        • 181
        Just recently change dev unit and drum unit.. cleaned transport pipe as well.. firmware up to date.. 2 new oem toner same thing...
        Sent from my HUAWEI VNS-L21 using Tapatalk
        • faxman28
          • 436
          check the gears on toner cart, used to get some toners were gear popped off and couldn't get it to stay on shaft. is toner coming out of cartridge.
          • Service@PRT
            • Oct 2016
            • 181
            first toner half the powder gone. but on the 2nd one... no.... i cleaned pipe going to dev.. but i guess dev although is new.. is damage..i hope not.
            • JLSam
              • Jun 2015
              • 605
              This.
              • Service@PRT
                • Oct 2016
                • 181
                Done everything i know... And i end up opening the unit xD
                Sent from Huawei P9 Lite
                • Service@PRT
                  • Oct 2016
                  • 181
                  This is what happen when something went wrong... From toner replenishment into f2-67.. such a time waster xD
                  fter cleaning... all works fine now.
