MX2640 taking firmware backwards
  • mttech
    • Mar 2014
    • 127
    Was wondering if anybody has taken firmware backwards. I updated this copier to newest firmware and am having problems with it. When customer enters accounting codes it will intermittently lock up with Please Wait in the display. When I am in sim mode I sometimes get a page that does not have the sub codes, or when exiting sims it will say exiting simulation and just hang. When any of this happens I have to use the main switch to power off machine. Would like to take it back to previous firmware but not sure if it can be done. Any insight is appreciated.
    • 22999
    Re: MX2640 taking firmware backwards
    I haven't tried it on Sharp.
    Kyocera and Konica Minolta write very detailed firmware bulletins specifying what versions you can back from/to, and how to do it. I imagine that Sharp is the same way. It will matter very much which version from and which version to. =^..^=
    • nottoosharp
      • 266
      Maybe the firmware file you used was corrupted?
      • SwisSeV
        • Jan 2016
        • 307
        Sounds like a bad update. Try update again from a freshly downloaded firmware file on a empty usb.
        • Al Mahn
          • May 2014
          • 2
          Is Customer using built in accounting or an add-on like paper cut? Could be compatibility issue. I have applied older firmware on other sharps for testing and had no adverse effects.
          • fireater
            Repair God? not quite
            • Apr 2006
            • 253
            use the firmware recovery method .. with the dip switches .. this forces all firmware to be rewritten. not just updated.. dunno about downgrading tho. never tried it
            I fix copiers ...Well Sorta
            • mttech
              • Mar 2014
              • 127
              So I updated this copier with fresh firmware and using the CN dip switch method. I am now able to access all my sims but still having issues when it boots up or powers down using the power button by the display. They are using the internal accounting mode but will still intermittently lock up with Please Wait message. When powering down with top button you can hear the fuser pressure release and then it hangs with Turning Power Off Message. When exiting a sim that reboots copier it hangs with Simulation Finishing message but you do hear the pressure release. Sharp told me I could take firmware back to previous version but it made no difference. I am thinking SD card now but looking for other ideas. I am not sure if the boot up and boot down are held on the SD card and forgot to ask Sharp.
              • mttech
                • Mar 2014
                • 127
                So, Sharp recommended replacing SD and CF card. I know the SD cards seem to have a high failure rate but was wondering if anybody has had problems with the CF card. Boot info is held on both.
                • mttech
                  • Mar 2014
                  • 127
                  Took a chance and the SD card solved problem.
                  • repn1999
                    • May 2010
                    • 310
                    If you need another SD card in the future I have come up with a way to make your own factory replacement sd cards. ALot cheaper than buying from Sharp.
