Light Cq
  • Sprint
    • Feb 2015
    • 10
    Light Cq
    I have 2 Sharp mx-m363 copiers that do the same problem. The copies have very light cq, I did sim 10 adj .The copies will get back to normal. But after a few days the copies will go back to very light. I have replace the drum and developer on both machines but I cannot get it to consistently stay dark . Help !
  • spanky
    • Sep 2012
    • 468
    Re: Light Cq
    change sim 46-19 AE_MODE from mode 2 to mode 1
    • nottoosharp
      • 266
      Re: Light Cq
      Are you using a third party toner? I've had issues with 363's and non OEM toner.
      • foudl
        • Mar 2010
        • 138
        Re: Light Cq
        I assume that you adjust your dev (25-2) with the toner bottle out...
        • nottoosharp
          • 266
          Re: Light Cq
          It won't run that sim without the toner in it.
          • SwisSeV
            • Jan 2016
            • 307
            Re: Light Cq
            25-2 is run without the toner. The dev unit is using the toner in the developer to create the reference value.
            • nottoosharp
              • 266
              Re: Light Cq
              Not in a 363. In color mfp you need to pull the toner but you will be unable to set density values in the black and white machines with the toner removed.
              • ZOOTECH
                Senior member of CRS
                • 3374
                Re: Light Cq
                I'm not sure about the MXM363, but there are several B/W machines that do require the toner cartridge be removed when running 25-1/2 ; you may have to cheat the front door. Check the install manual. There was a shipload of machines that sat on the dock during a strike, and the toner add clutch plates rusted adding toner when not needed (overtoned).
                • nottoosharp
                  • 266
                  Re: Light Cq
                  Fortunately the machines usually throw up a "check toner!!!" When you have done it wrong.
                  • onetek
                    • 318
                    Re: Light Cq
                    Yeah on this series machines, toner should be pulled out for sim 25-2. Once or twice, we had to replace the complete dev unit as well as transfer to get back to a nice CQ. (one of our 363 is over 2000 0000 copies).
                    • faxman28
                      • 436
                      Re: Light Cq
                      Below is from the mxm503n series SM page 4-3
                      Toner density control reference value
                      setting
                      This adjustment is needed in the following situations:
                      * When developer is replaced.
                      NOTE: Be sure to execute this adjustment only when developer is
                      replaced. Never execute it in the other cases.
                      1) With the front cabinet open, enter SIM 25-2.
                      When setting the toner density control reference value, pull out
                      the toner cartridge in advance
                      2) Close the front cabinet and press [EXECUTE] button.
