Sharp MX4100/3100/5001 black and color dev unit swap?
  • buzz
    • Aug 2013
    • 288
    Ok, I got a whole bunch of used color dev units that are still good... bushings, mag belts, augers all intact from the boneyard. I came off the field the other day with a 4100 and 5001 black dev unit binding. I'm all out of black dev units to use.
    question: can i use the color dev (CMY) in the black slot? I realize I need to vacuum out old color dev and re install w/black dev. The reason I ask is that the part numbers for each is one digit different (last digit DUNT-7457DS1/2/3/4).
    Wondering if someone already tried this yet?
    Also, swapping between 3100 and 4100, numbers are different, swappable?
    Thanks for any feedback.
  • faxman28
    • 435
    Re: Sharp MX4100/3100/5001 black and color dev unit swap?
    The dev units have chip and can't be swapped unless you swap out the the wire harness on dev units.
    • repn1999
      • May 2010
      • 310
      The harnesses are pinned differently for each color, and for black. so not they will not interchange without alot of work.
