Sharp MX2614 - C4-00 Error
  • Leebs14
    • Feb 2014
    • 457
    [Error Code] Sharp MX2614 - C4-00 Error
    Ok, called out to a MX2614 today with a C4-00 code, replaced the PTC Unit and then it got interesting!!
    Machine works ok when using mono but when you try to copy or print in colour the C4-00 code comes back.
    Cleaned ID sensors, Drums etc but the fault remains.
    Anyone come across this?
  • OlliK1969
    • Nov 2016
    • 310
    Re: Sharp MX2614 - C4-00 Error
    Hi
    please control this CCE1479.pdf
    • Leebs14
      • Feb 2014
      • 457
      Originally posted by OlliK1969
      Hi
      please control this [ATTACH=CONFIG]35229[/ATTACH]
      • Hansen88
        • 1055
        I had this problem before. You need to replace the transfer switching clutches in the back of the machine. If you take off the toner waste bottle and run a black copy and watch the black cam on front of the transfer unit and then run a color you will see that cam move as the clutch slipps and then you get the code. you have to remove the whole drive assy that goes across the back of the machine to replace the clutches. Its not very hard to get off.
        • Hansen88
          • 1055
          Ok,I see what I posted about the clutches is the same as the bulliten from the post before from olik1969. I have found this to be almost as common as the board causing the problem.
          • repn1999
            • May 2010
            • 310
            Replace the transfer control PWB . We had a 2610 do the same thing. Replaced the primary and secondary belt units and both main power boards, the ptc and did a full pm and still were dead. Replaced the transfer control pwb and now works like a champ. RDENU0133FCPZ TC PWB
            • Sharpshooter
              • 21
              Check that Transfer PWB has not been fitted correctly.
              See the attached file.
              C4_00.pdf
              • Leebs14
                • Feb 2014
                • 457
                Changed black & colour transfer belt clutches and it's sorted.
                • vlad_
                  • Jul 2008
                  • 98
                  I also had problem C4-00
                  A malfunction of the high-voltage unit is detected.
                  Out of order: transistor, diode and fuse.
                  The photo is attached.
                  • ruben
                    The New Guy
                    • Oct 2012
                    • 1203
                    This part has since been modified to prevent this, new P/N is RDENU0154FCP2.
                    See: MX2614N-MX3114N256.pdf
                    • vlad_
                      • Jul 2008
                      • 98
                      See: [ATTACH]36378[/ATTACH]
                      Sharp asks for a new RDENU0154FCP2 money (Price
                      Rank BW !!!). Why should users pay for factory errors?
                      I will cut the path and solder three zener diodes of 150 volts.
                      • vlad_
                        • Jul 2008
                        • 98
                        Today checked: After the replacement, ordered from ctha transistor, diode and fuse, the board earned as it should!!!
                        Transistors from China went for a long time, but they came. They have no analogues! https://ru.aliexpress.com/item/5Pcs-...608.0.0.H57lYY
                        • Michmich123
                          • Nov 2013
                          • 24
                          I checked this out , i have ordered the fuse and Transistor (as a referencetype) .
                          the diode dont have a Type printed on her Surface . Also i solder it out and Test it by normal way . They dont have a defect .
                          I replaced Transistor and fuse. Modified with the three Zehner diodes and Test the Board.
                          Heureka it works.
                          Made this with 5 other "c4-00" boards and all of the will working well.
                          • vlad_
                            • Jul 2008
                            • 98
                            Heureka it works.
                            I'm happy for you
                            • Gallus
                              Issue fixed for me too. Sorry for posting in an old thread.
