AR M317 drum & developer
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Been awhile since I worked on a Sharp. Going out to a call today to install drum & developer in a M317. What settings need to be done? I remember doing sim 25 for developer when I use to work on a lot of sharps, is this still the same?
    I have the manual but you know how they are, not too detailed.
    Thanks in advance
  • laitang
    • Nov 2012
    • 627
    Re: AR M317 drum & developer
    From service manual:
    SIM 24-7 to clear the OPC drum counter when replacing drum.
    SIM 25-2 to make the initial setting of toner concentration when replacing developer
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      Thanks laitang. Looks like sharp still uses the same settings I remember.
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        Don't forget 24-5 to clear DV counter.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4723
          Update, EL error
          Thanks Akitu, I didn't see your message until after I had left.
          After running 25-2 it came up "EL error". Could this be because I didn't clear developer counter?
          • Akitu
            • Oct 2010
            • 2595
            Re: Update, EL error
            EE-EL means it's overtoned. Run a couple of skyshots to even out the toner mix. It's a strong possibility that not clearing the counter is related, but check your density sensor just to be sure if you don't think it was the counter.
            • Jaws
              • Oct 2007
              • 236
              I have had a lot of success by cleaning the film off the density before adding new developer. I try to do it on all these ARM machines before adding developer.
              • dwarf
                • Oct 2012
                • 168
                set-up of dev should be done without the toner cartridge installed...
